I am preparing a kitchen cupboard and the worktop for an LPG (propane) hob which will be fitted by a Corgi reg fitter.
The hob instructions state that there should a 5mm gap between the worktop and anything beneath. I assume this is to prevent a gas buildup in the cupboard should a leak develop. This makes sense for natural gas which is lighter than air, but propane sinks. I have complied with this, and also intend to seal the back so that gas cannot leak down behind the unit and into the void behind the plinth. But are there any other recommendations for ventillating the cabinet?
A second question. I understand that a tap should be fitted close the hob. If this is under the hob in the cupboard, it seems to me that this is introducing something else that can leak in an enclosed space. Is this a requirement or a recommendation? There will be an emergency tap fitted at the bottle end of the supply pipe which is just under 3m long.
I know the Corgi guy will have an answer, but people do interpret regs differently, and I would just like to get an opinion.
