vokera hot water
13 Aug 2012
Yorkshire
Hi hoping for some help, just replaced a rad (furthest from combi boiler) and after a failed joint have repressurised and bled ch all ok.
However now have no water out of hot taps at all on either water only setting or joint hw/ch setting. what have i done? is there a simple fix? Mrs jg will not be happy at bath time!
thanks john
Check you've turned the water supply back on, refer to instruction book for correct position of valves
