How did you check it and what were the actual results????
Tony
Kamco:-
The advice not to use X2 on a Linea is only on the CONDENSING model ( the HE ). So far you have told us that yours is a "Linea 28" and NOT an HE model!!!
Just measuring the maximum burner pressure is not enough!
But as you are not CORGI registered the only advice I can give you is to get a competent CORGI.
Otherwise MOD 10 would just delete what I have written without giving any explanation even though he is not qualified to judge what is or is not "inappropriate advice".
Last time he did that I did not get the courtesy of a reply from the site Owner either!
I should add that I fully support that action but it should be consistent.
If you are CORGI then in future post these questions in the Combustion Chamber section on this site and we will know that you are registered and we can give you advice on gas related matters.
