Washer to join Male Comp Gland to Enclosure?
Use mine ALL the time. Not really sure how I coped before buying one tbh. And the holesaws only really come out for metal now
Tried a few drill bits to no avail until I used a 20mm flat wood bit to carefully make 2 holes in the Enclosure and it worked like a treat. Can I use a 15 Amp connector strip on 2.5mm cable or will it have to be 30 Amp to connect both 2.5mm cables? It's a spur which will feed from the Enclosure a 2 gang socket, a 1 gang socket and an FCU for the gas boiler. Thanks again.
