I have a Bosch Exxcel 1400 Express and it keeps filling up with water when not in use. The water is clean. I have checked the waste pipe outlet and everything is clear. Can anyone help?
The water is allowed into the machine courtesy of an electrical solenoid valve...I guess this has stuck partly open.
If you want to investigate, its just behind the water inlet, with the top of the machine removed (and electrically isolated!)
John
