Hello All,
Last year i replaced the guttering on the garage roof, and took that opportunity to add a downpipe for a water butt.
The guttering did run along the roof and down a iron downpipe into the ground somewhere? in my wisdom i decided to add another downpipe the other side for the waterbutt. Reason being, putting the waterbutt the same side as the iron pipe would block access to the side of the garden in a opening that is already just big enough to get a motorbike down (yes important ).
In a further stroke of genius i did not connect the guttering to the existing downpipe, as this would have effectively cut my water collection in half, and i want all the rainwater i can get
Now i have considered that all of the water from the garage roof is collecting in the waterbutt, and as it only really takes 1 day of heavy rain to fill up, it will be overflowing all over my patio and (potentially) causing damage to the garage foundation (true?)
So i wonder is there any easy fix, without removing or moving the water butt?
What i really hope for is a way to open / close the downpipe to the waterbutt and the drain so i can fill the water butt when needed and block it off when its full
