The water tank is in a cupboard in my bedroom in the rented house i live in.
The ball cock valve has been replaced once, then adjusted and the ball float has also been changed.
I can do some washing up in the morning and return home 8 hours later and it will still be dripping. The maintenence dept of the letting agency have given up and i'm so fed up of hearing that drip that i will have to move out if i can't make it stop. The only way it will shut up is when i reach up and pull on the tap and manually fill it up, so it drips no more. How long should a water tank take to fill up if you haven't used much hot water (aka washing up/washing hands)
Any help is greatly appreciated
PS if you click and look at my profile i have uploaded a pic of my limescale ridden tank... its the brass valve fitting that drips
