wf541p
17 Mar 2013
Armagh
hi can you advice me on my hotpoint wf541p everytime i switch on the door lock button flashs an machine wont work i have replaced the interlockin switch but still the same help would be appeciated thanks have also tried blowin down the black pipe but nothin
When u changed the old lock was it a red one. Is the new lock white. Did you change the wiring block round the other way. Check the pcb you may have blown tracks on it.
rocks1";p="2709492 said:
When u changed the old lock was it a red one. Is the new lock white. Did you change the wiring block round the other way. Check the pcb you may have blown tracks on it.[/quote
its a white switch an wiring block only fits one way. the wash button is luminated but wen i press start button door lock button shud light but it doesnt jus sits with the wash button lit thrn aft abt 10 mins door lovk button flashes ]
Check motor brushes there worn down.
