Hi all,
When the central heating is on the overflow pipe leaks outside from the loft?
When it's off it doesn't.
Any theories chaps?
I'll get up there later if anymore info would be useful?
Rob
Should only be a couple of inches of water in the tank, turn supply off then take a few jugs of water out (or use drain off), bend ball valve arm down, turn supply back on and make sure water stops, it could be washer or split coil.
