A
Alarm
Oi, I mentioned "Ducks" first, so keep out of it
@aptsys - Yes. Electrons look for the quickest, easyest or shortest path to ground/earth. They don't care whats conducting them, so long as it can carry them.
Which way do electrons flow in an AC circuit?
Sorry,
I'll go for *Leaps for cover* then
@Aptsys, you tell me. The clue is in the name, alternating current
So why are electrons going to look for the shortest path to ground/earth?
Think, instead, of a rigid, inelastic rod.ie. think of a wave pool, and a rubber ducky going up and down on the wave. The rubber ducky is the electron. At the end of the pool the energy is emitted.
As soon as one end is pushed, the other end moves. And it begins to move no matter how slowly the rod is moved. This is analogous to the speed of propagation down a cable.
If you never change the direction, then eventually the end you are pushing will get to where the other end was when you started. But if you push and pull, repeatedly, your end will never get to where the other end was when you started, even though the other end is also moving all the time. This is analogous to the movement of electrons along a cable.
What ebee has just said about calling this particular connection 'neutral' is correct, it is just what we are perceiving. Interestingly, something I was recently tought is that both the live and neutral connections can be considerd 'live', which is why technicaly speaking, live is normaly 'line' connection. But that is for another discussion.
You would get a shock because the electrons are looking for the quickest way to ground, which in the case of this would be you..
The majority of the current will still flow through the neutral conductor & back to the star point of the transformer, as it was doing before you touched anything.
matt1e";p="1986814 said:Not if the circuit isn't energised it won't
I.e if you touch the live side of a switch thats in the off position for example
Yeap, fair point.... I did assume a normal, healthy, operating circuit that was actively powering something......
