- Joined
- 12 Mar 2016
- Messages
- 222
- Reaction score
- 1
- Country
Good morning all,
I have a Vokera boiler and sometimes it keeps going off and on when the hot tap is running, like it will fire up run for a few seconds then turn off for a couple of seconds then back on again, over and over and over. So the water gets hot and then cools and then hot again and so on obviously.
Sometimes its ok, and if I turn off the hot tap and back on again but not at full pressure it works fine again. Any ideas what the issue could be? It just had a brand new part, I dont know what it was called now but it completely stopped working and needed a new board or whatever its called in January
I noticed the water pressure it at 0.5 when the boiler is in use and not in use. SHould it be higher? if so, how do I change it?
Thank you all in advance
