looks like it's down to interpretation as to what is a "normal 60w bulb" could have saved some time if you had described it as an energy saver to start with.dena007 said:Hi, it's just a normal light with a 60 watt screw-in bulb
FFS - you were explictly asked the question!dena007 said:Now working fine!!
I tried a different bulb & there is no longer a delay. The original bulb I was using was one of those energy efficient low wattage - 15 I think, but still gives the same 60 watts brightness.
I've put in down to that as all seems to be fine now?
Thank you
i'm not a huge expert on how low energy bulbs work but i think they need to charge up before there is enough voltage on the output contacts to strike an arc in the tube
You should be thankful that you didn't do that for a light controlled by a dimmer.....dena007 said:Sorry, I just grabbed the nearest bulb available in my spares, it was only when playing around with it yesterday that I noticed it was one of those special low energy type ones.
link to circuit diagram of above: http://members.misty.com/don/linefl.giffelix said:FAO Plugwash (and anybody else who's interested):
Electronic starters get rid of the gas discharge lamp and bi-metal strip. They conduct initially then break the circuit after a preset time delay. The effect on the tube is the same but one size now fits all. In the new compact fluorescents even the ballast is electronic. The starter circuit must break the filament current and also generate the voltage spike.
Although not recommended It has been achieved before at work but a dummy resistive load had to be plugged in parallel across the dimmer albeit the dimmer in question was a "professional" type with specs to drive flourescent lighting.securespark said:Our friends in Yorks have a couple of wall lights with CFL's and they're on a bog-standard dimmer. Funnily enough, it works a dream!
Never seen that before or since!
