View media item 21579
I find it hard to follow what is going on at a switch without testing for live and switch live
Right hand side is a two way switch with strappers
Yellow in com will com to com in other switch
blue in L2 will go to L2 in other switch where there will be a switch live
red in L1 will be perm live which will go to L1 in other switch also with perm live
red in L1 linked to other switch to provide perm live.
This is where I get a bit confused
now the left hand side
the red in L1 will come live when the switch is on
the black in L2 will come live when the switch is off
wont that light always be on
STUDENTSPARK,
If you study the right hand switch, somewhere further along will be another 2 way switch. Now either at this other switch, or at a jb, or at the rose; the blue will be connected to the sw live, the red to the perm live.
The easiest way to imagine this would be to think of a conventional master 2 way switch; where you have a 2 core in red and black which is this switch wire from a standard 3 plate rose. This red is perm live. At the switch it connects to the red of the 3 core which also then becomes perm live. This red then goes on to feed the lefthand switch in the picture.
The lefthand switch will feed another 2 way switch via the strappers. At this next switch the common terminal wire will feed the light.
You will notice at the righthand switch the perm live is at L1
and
at the lefthand switch the perm live is at COM.
Quite normal.
With two way switching there are countless ways of doing it; when it comes to re-wiring or altering wiring all these methods are used to make the job easier, usually.
