At the moment the cable comes from the old all in one cooker into the cooker conenction unit and then back to the fuse box with a 45A fuse. Is a 45A too high a fuse? I only know that the hob is 5.8Kw not sure about the oven but it is a single fan oven so probably no where near the hob. Does that mean that the setup at the moment is wrong and that I would need a lower amp fuse. If so what ampage would this be and can you still get the old style plug in fuses.
Please can you also explain the best way to wire up the hob and oven
Thanks.
Thanks.
