If its a standard washing machine F15 = drain problem....pump blocked/faulty, drain hose blocked/kinked, plumbing issue etc.
If its a washer/dryer F15 indicates a faulty dryer relay.
Did post details the other day but no info was forth coming-
ariston washingmachine
avxxl105
power,spin and 4 of the option led are flashing and machine does nothing called a company and was told it was fault f15 but unless we got engineer out they wouldnt say what the code meant!
