I have a problem with CH preasure
I have checked the expansion cylinder valve and ait comes out.
I lowered the preasure which holds at 3 bar to zero pumped up the expansion cylinder untill preasure was 0.5 bar then refilled the system untill preasure reached 1 Bar.
After the CH had been running for 1/2 hr the preasure was back to 3 Bar
The preasure does not change from 3 Bar even when not in use overnight
Is the expansion cylinder OK
or is the problem with the water to water heat exchanger
Could some one help please
