Hi folks,
I have a worcester 240 combi boiler and it has started doing strange things. The hot water side if fine its just the central heating side that has started playing up.
When the heating is switched on it can run fine then for no apparent reason the burners drop out and a loud clicking sound can be heard. The heating then goes into a dropping out and quickly re igniting itself for a while. Then it appears to settle down after about 15 minutes.. also sometimes it will not fire up when demanded.
The hot water switches on and off ok and does not seam to have any prople so I assume that the fault is purely on the ch side of the unit.
It is regularly serviced and we have had no proplems up till now.
I called a service engineer out after its last grop out and when he switched it on it came on ok but the next day when I switched it on it wouldnt start.
