Read the regulations. I think you will find it is 10% per transmitter,The only issue I have there with what you were saying was the compliance issue.
The system that was losing packets was transmitting 80% of the time due to looking for lost packets.
Most wait for a clear channel before attempting to transmit. Only possibly if sensors also have receivers.In the scenario you have described if everyone had systems that relooked for lost packets then this scene could be repeated anywhere as each system tried to get it's voice heard above the others.
A valid point, but can be explained by variations in field strength between the two houses. A signal not continuous enough to trigger jamming detection will still be enough to corrupt activation signals to the point they are recognised.The only logical error I can see in your tale of events is that Mr Day had turned off his jamming detection but his neighbour had not.
You then said that if the alarm had sounded it would have prevented the burglary as people would have heard it.
Door sensor had worked reliably for several months.
