Zafira fan
6 Nov 2023
Bedfordshire
2010 Zafira. Fan used to run at 113 degrees.. strange right? Now it doesn't even run. Temperature at 127c and fan not kicking in. All relays test okay...
At 100 degrees without the fan running should I be worried? I mostly do short trips... doesn't state anything on the manual...
I am reminded of my old Metro...
Driving in slow summer traffic meant having the heater and blower on maximum, windows down and getting very sweaty :mad:
I'm glad cars are a lot more reliable these days! :)
Check the connections at the fan! I had a 1986 Astra 1.3 which nearly cooked becuase the fan connections were corroded!
Check the thermal switch.
If you short the switch out, does the fan run?
And, of course, the obvious. Fuse.
