| Author |
Message |
paul78
Joined: 05 Jan 2010 Posts: 266 Location: Merseyside, United Kingdom Thanked: 24 times
Posted: Sun Feb 13, 2011 10:26 pm |
just curious what you pros do with prepping the bathroom floor....
wbp 18mm at least... even if it raises the floor higher than next room?
same height wbp in mm to match the next floor?
im thinking strength is more important than the two floors being same height, so sacrafices have to be made???
also do you prime the wbp or only if the (flexible) adhesive bag advices it. |
| Back to top |
If you do not want to see this advert, click here to login or if you are new click here to join free. |
vv2806
Joined: 21 Feb 2008 Posts: 401 Location: Cardiff, United Kingdom Thanked: 36 times
Posted: Sun Feb 13, 2011 11:40 pm |
I am not a pro, just tiled the whole bathroom. The floorboards were rotten but even if they were not, I would remove them anyway. Then made the new floor from WBP. In this way the difference in the levels is not so big. Finished it with a threshold from B&Q, they and the other sheds sell thresholds suitable for different levels and different floor finishes - tiles and carpet in my case. |
| Back to top |
jefoss
Joined: 11 Dec 2006 Posts: 2141 Location: Leicester, United Kingdom Thanked: 19 times
Posted: Mon Feb 14, 2011 12:18 am |
when you say 18mm are you talking about total replacement of the floorboards or overboarding?
total replacement should be 25mm and overboarding is 15mm minimum (imo) |
| Back to top |
JohnD
Joined: 15 Nov 2005 Posts: 34357 Location: Hampshire, United Kingdom Thanked: 1087 times
Posted: Mon Feb 14, 2011 1:05 am |
I'd go for pulling up the old floor and re-doing it in WBP. I recently did a large room like that, with noggins under the short edges. It is firmer, stronger and more rigid, and i think quieter too. If you can carry an 8x4 sheet into teh room, you should have very few joins (which are where most flexing is found)
I used 18mm but this was not to be tiled, maybe the 25mm is even more rigid, I don't know. |
| Back to top |
lancenotalot
Joined: 22 Jun 2004 Posts: 859 Location: United Kingdom Thanked: 43 times
Posted: Mon Feb 14, 2011 10:19 am |
12mm ply to overboard or 6mm backers |
| Back to top |
paul78
Posted: Mon Feb 14, 2011 10:53 am |
any recommendations on the addy/grout etc i think bal flexible for both just for the added peace of mind, also do i leave an expansion gap around the perimeter of the floor for the ply |
| Back to top |
jctilingservices
Joined: 29 Oct 2009 Posts: 993 Location: Tyne and Wear, United Kingdom Thanked: 130 times
Posted: Mon Feb 14, 2011 3:58 pm |
6mm tile backerboard or at the very LEAST 12mm WBP ply, if you lift your boards to replace with ply (not overboarding) you will have to seal the underside and edges before fitting, also dont nail the ply, screw it at 150mm centres
Bal single part flexi will be more than up to the job  |
| Back to top |
paul78
Posted: Mon Feb 14, 2011 5:56 pm |
thanks for the replies guys, be lost without this forum. |
| Back to top |
Tully
Joined: 15 Sep 2010 Posts: 12 Location: Norfolk, United Kingdom
Posted: Thu Feb 23, 2012 11:13 am |
Hi guys i have a sturdy floor but its made of OSB 18mm thick is that okay to tile onto if say I prepped it with a covering of primer/pva / |
| Back to top |
prceramics
Joined: 18 Jan 2012 Posts: 82 Location: Buckinghamshire, United Kingdom Thanked: 6 times
Posted: Thu Feb 23, 2012 12:07 pm |
| Tully wrote: | | Hi guys i have a sturdy floor but its made of OSB 18mm thick is that okay to tile onto if say I prepped it with a covering of primer/pva / |
chipboard ? |
| Back to top |
Tully
Posted: Thu Feb 23, 2012 1:47 pm |
Yes its an external chipboard is that no good ? |
| Back to top |
prceramics
Posted: Thu Feb 23, 2012 7:14 pm |
| Tully wrote: | | Yes its an external chipboard is that no good ? | i would put a cement backerboard down first mate |
| Back to top |
tictic
Joined: 06 Oct 2009 Posts: 1338 Location: Glasgow, United Kingdom Thanked: 166 times
Posted: Thu Feb 23, 2012 8:55 pm |
Don't put anything ontop off the osb....
Lift and replace with wbp ply...seal underside and edges prior to fixing ply down with acrylic primer...
Osb is like weetabix....you will need fix cement boards down ontop off it with a SPF....thus turning it into weetabix.... |
| Back to top |
Tully
Posted: Sun Feb 26, 2012 6:17 pm |
Thanks Guys, I am widowed female the builder that fitted it said it was marine ply athough it looked like chipboard to me no no he said thats a special looking ply. I only worked it out when I saw one of the bills and some of it got wet yes just like weetabix your spot on anyway...his coming around tomorrow to chat about it.
I try and do most things myself this was too physical for me. Your help is always great thanks again not sure what I will say to him but chin up.
x Tully  |
| Back to top |
Tully
Posted: Sun Mar 04, 2012 6:07 pm |
Hi Guys well contractor not interested in changing it was very nasty but what the heck moving on been into local merchants they have the following which they tell me is a boil plywood ? if I buy and cut in small runs with my jig I should be able to fit it by myself and get rid of the OSD been into the yard and the stamp on the ply is 2x EN636 2 EN314 2 Ext E2 any good ? to replace OSB floors in upstair bathroom so that I might tile it do I need to varnish it/ seal it in some way basically is this fit for purpose? CE 0407CPD 436 2x EN636 2 EN314 2 Ext E2 |
| Back to top |
