I am about to change my current, aging Baxi BBU with a new condensing combi boiler. I am torn between these two. Anyone had any experiences with either? Good/bad reports? Suggestions?
If you have enough water coming in go for the Highflow.
Having said that the condense lifter is a single point of failure, and the flueing arrangements are even more limited than the 40CDi. Can't use plume diversion with 440, for instance, it's an older design and incompatible.
