DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Digistat - Worcester
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
mtorrens
from United Kingdom
PostPosted: Tue Oct 02, 2007 9:45 am Reply with quote
I have a combi boiler, with a wireless Worcester Digistat thermostat. The signal between the Digistat and the boiler is fine - i.e. I can turn the heating on and off and use the timer.
The fault is with the Digistat - the thermostat pert of it does not seem to be working - i.e. set temp to 21 but the heating never turns off and the house gets hotter and hotter. Basically, without the thermostat, it is just an ON/OFF switch.
My question is, can I buy a new Digistat to communicate with the card in the boiler, and how do I know which Digistat to buy? Oh yes and where can I get one from!
Thanks guys.
Back to top
 Alert Moderators
simond
from United Kingdom
Thanked: 281 times
PostPosted: Tue Oct 02, 2007 8:09 pm Reply with quote
Your post is a little confusing but I think you mean that the boiler clock and RF receiver functions correctly, but the RF thermostat doesn't.
These products are known to be a bit flakey, being based on the old fashioned Drayton RF controls. The first thing you should do is attempt to replace the batteries in the order described in the manual, and re-bind the radio link.
If this doesn't work, check when your boiler was installed. If it is less than 2 years ago (or considerably longer if we installed it icon_lol.gif ) Bosch should have it covered under their warranty. Assuming you have had the boiler serviced on its first anniversary and the installer was bona fide.
Otherwise, it is a complete new part (clock and transmitter).... icon_cry.gif
Back to top
 Alert Moderators
mtorrens
from United Kingdom
PostPosted: Wed Oct 03, 2007 7:54 am Reply with quote
Thanks for your post and apologies for my confusing one!
Yes, you are right - the the boiler clock and RF receiver functions correctly, but the RF thermostat doesn't.
I have replaced the batteries and re-linked thr radio - same result. The radio signal works, but the thrmostat does not.
The boiler was installed by the previous owners, however I know it is more than two years old.
When you say a whole new part, do I just have to buy the handheld digistat device, or do I need to buy the receiver part that is in the boiler? I was thinking (hoping!) that as the radio communication works, I would just be able to replace the handheld device?
Is this the case and, if so, how do I know which is the correct one to buy? I have had a look around and there are lots of models?
Help!
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Digistat and Worcester 24i Junior 10 1060 Fri Nov 13, 2009 5:37 pm
Worcester Bosch Digistat transmitter issues 4 1300 Thu Jul 02, 2009 11:18 am
Drayton Digistat +3RF to a Worcester R40HE Plus 2 380 Wed Nov 18, 2009 9:20 pm
Worcester Bosch DT10RF digistat showing 0 degrees 7 200 Mon Apr 01, 2013 1:30 pm
Worcester T45 Digistat + Drayton SCR 5 80 Sun Apr 07, 2013 5:33 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
