DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Installing a Shower Pump to an existing Gravity Fed Shower
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
Taters
from United Kingdom
PostPosted: Fri Oct 12, 2007 10:24 am Reply with quote
I am looking at installing a shower pump to my existing gravity fed shower. I have read numerous posts on the forum after doing a search, but am still slighlty confused! (Some would say thats not hard)
The current arrangement is plumbed in as follows, this is how it was done when the house was new.
The cold has a separate feed off the cold water tank in the loft runs approx 8' along floor of loft then down wall to mixer (Mira 8icon_cool.gif
The hot is fed as follows:- There is a single pipe coming vertical out of the hot water tank, which after 6' turns 90 degrees for another 6-8' before it is T piece off on the vertical. Now looking at the pipe run, the pipe that runs down from this T joint is, I guess, the hot water feed for the rest of the house. The pipe that runs up from the T piece goes into the loft loops round up over and ends above the cold water tank, and I guess this is the vent for the hot water system.
As this vent pipe passes through the ceiling/loft floor there is another T joint which then feeds the hot water supply to the shower.
The shower head is approx 2 1/2' below the cold water tank but is above the hot water tank.
I was originally going to add a pump to the two runs in the loft as this is the easiest, installation wise, place to fit it. After having read the forum I am now concerned that air would get trapped!
Also if I try to fit the pump somewhere in the air cupboard then obviously the cold feed is miles away in the loft!
So after that long build up heres the questions:-
1.
As there is currently no problems with air in the shower system would the fitting of a pump (positive head ) in the pipe run in the loft work? (Obviously I would have to protect against frost etc)
2.
Is the only way is having to change the pipework in airing cupboard with a new flange, (Surrey, Essex, etc) then completely repipe the hot and cold feed to the shower?
3.
Any other suggestions.
Many thanks in advance for any help and advice given
Back to top
 Alert Moderators
hi-spec plumbing heating
from United Kingdom
PostPosted: Fri Oct 12, 2007 10:53 am Reply with quote
Taters wrote:
1.
2.
3.
you can fit the pump in loft cut straight into the cold feed.
fit a surrey flange to the hot run a new pipe into loft then where it t's off existing pipework cap that off , then join your new pipe to existing shower hot feed.
after the surry flange you must fit a gravity loop
Back to top
 Alert Moderators
Taters
from United Kingdom
PostPosted: Fri Oct 12, 2007 11:24 am Reply with quote
Thanks for the quick reply and comments.
I contacted Salamander with regard to which pump to use, and the have suggested the RHP75 as after carrying out a natural flow test it would seem the shower has a positive head.
I just wondering why they suggested this one as it seems to be designed for pumping the whole house rather than the RSP75.
The did suggest the ESP75CPV if it was negative head.
Anyway I digress from topic of thread, thanks once again for your speedy reply.
Back to top
 Alert Moderators
kneenaw4
from United Kingdom
PostPosted: Tue May 19, 2009 12:40 pm Reply with quote
I had a twin impella pump fitted last week. My plumber tapped into the top of the cylinder using the new Wessex flange (not Essex) with air release mechanism to avoid air locks, and then ran a new feed from the cold water storage tank into the other inlet. Works a treat good pump 98.00 from tool staion free delivery next day job done. Fiddly though
Back to top
 Alert Moderators
seco services
from United Kingdom
Thanked: 1245 times
PostPosted: Tue May 19, 2009 12:49 pm Reply with quote
why have you posted on a 2yr old post ?
Back to top
 Alert Moderators
kneenaw4
from United Kingdom
PostPosted: Tue May 19, 2009 7:20 pm Reply with quote
LMAO, i only noticed after i'd posted it and felt a right knob lol. He's probably done the job and since moved house.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Installing a gas fire in an existing fireplace 3 720 Sun Jul 09, 2006 6:40 pm
Installing a VRT392f in an existing Vaillant ecoTECH pro28 2 80 Sat Apr 04, 2015 2:04 pm
Installing new toilet to existing cast iron waste pipe 3 1340 Tue Oct 07, 2008 4:25 pm
INSTALLING PUMP ON GRAVITY FED WATER SYSTEM..HELP!!! 5 5760 Sun Apr 13, 2008 8:25 pm
existing pump, new shower, no water! 10 520 Wed Jan 25, 2006 10:32 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
