what boiler to replace my potterton envoy??
22 Dec 2007
hi all
ive posted on my thread about the boiler probs aswell .
basically my envoy boiler is knacked!!!
i need to replace it with a new boiler, does it have to be the condensing sort??
can anyone recommend a good boiler to replace it that willbe reliable.
i dont have a big budget (£1000) to buy and get it fitted.
is there anything that is compatible with the original pipe work.
if the boiler was that bad is it worth getting the rest of the system flushed through??
sorry for all the questions but i need to get it sorted.
thanks and happy new year.
steve
the system HAS to be flushed
and 1000 IMHO will not be enough by a fair old way
You may find you need more of a budget for replacing the old and yes it does have to be condensing.
Whats the issues with the envoy anyway?
the boiler was full of water aparently upto the level of the pilot light??
one of the sensors is knackered .
the plumber said he could repair it for around 150 but coldnt garuntee how long it would last.
not been use in years you see
Ah ok, the condensate traps probably blocked then.
Unfortunately your budget wont really get you much boiler wise. Probs worth getting the envoy fixed and keep it going untill you can afford a bigger budget.
i can stretch to a bit more to be honest but it cuts into my decorating fund!!(first house you see)
is the original pipework usuable or does it need to be different for difeerent boilers???
what would you recommend please boiler wise(condenser)
A thousand quid to supply and fit a boiler will get you nothing but a cheap piece of junk fitted in a sloppy way. That will probably mean that you are back to start in under 5 years and possibly hundreds of pounds in repairs.
First, make sure your system gets cleaned thoroughly and sufficiently protected with inhibitor. If the boiler is leaking internally, it is almost guaranteed to be full of all sorts of drab that has ruined your current boiler.
Search the forum for similar problems and read the FAQs to get an idea what is involved
what would you recommend as a good value for money boiler for a 3 bed end terrace house with a rad in each room (7 ithink)
cheers
steve
Depends on a lot of stuff but I would hesitiatingly suggest about 2K for a new boiler/ trvs in bedrooms and a powerflush
BTW lads that is only a suggestion not a redflag to have a go at old CM ok
any good value for money boilers to look at??
cheers
steve
The Heatline are fairly cheap but like any boiler needs properly fitting on a clean system so will still cost about £1500 upwards.
Why not downsize your car???
Tony
