DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Flashing Light
Goto page 1, 2  Next
Author Message
radsik
from United Kingdom
PostPosted: Sat Apr 26, 2008 4:45 pm Reply with quote
I have a strange problem that I hope someone can help me with.
The light on my landing flashes on and off when the switch is in the off position, I think if I change the positions of the light switch downstairs it stops but as it is totally random I have not been able to actualy confirm this, the switch downstairs controls both the lounge light and landing which are on seperate rings. In addition to this the smoke alarm started randomly going off in short bursts last night, this takes it 's power from the landing light so i am thinking it is connected to the flashing bulb.
My take is that the switch downstairs is faulty, letting current pass through from the downstairs to the upstairs ring giving the bulb (compact flourescent) a short 'pulse' of power. As it is a 15 quid switch I don't really want to replace unless I am sure it is at fault icon_smile.gif
Thanks for any help.
Tim
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 24 times
PostPosted: Sat Apr 26, 2008 5:03 pm Reply with quote
life is like that, CFL's will do as you have when on a 2 way cct.
Back to top
 Alert Moderators
radsik
from United Kingdom
PostPosted: Sat Apr 26, 2008 5:15 pm Reply with quote
ok, thanks, is it likely to be related to the smoke? If that is a seperate issue then I will replace it.
Back to top
 Alert Moderators
daytona
from United Kingdom
PostPosted: Sat Apr 26, 2008 5:18 pm Reply with quote
it sounds like capacative coupling,its not dangerous and you dont have any faults.dont worry about it.
please dont replace it with a normal lamp,were trying to get away from pointless wastes of energy icon_wink.gif
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 307 times
PostPosted: Sat Apr 26, 2008 5:43 pm Reply with quote
£15 switch?
Back to top
 Alert Moderators
radsik
from United Kingdom
PostPosted: Sat Apr 26, 2008 6:29 pm Reply with quote
Thanks for the replies. It's not a dimmer, just a 2g toggle type switch.
If it's not dangerous thats great but my main concern now is the smoke alarm going off randomly. It has happened a few times now, including at 3am last night which scared the **** out of me and the wife, my daughter slept through it somehow even though it's outside her room icon_confused.gif
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 24 times
PostPosted: Sat Apr 26, 2008 6:57 pm Reply with quote
cfl lamps flashing can be anoying, do change it its only 1 lamp.
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 307 times
PostPosted: Sat Apr 26, 2008 9:43 pm Reply with quote
Kids and teenagers can sleep right through these things - research & experiments has been done in the States to prove that they sleep through ordinary alarms.
What wakes them is an alarm with a recorded message, ie parent's voice saying "WAKE UP (NAME), THERE IS A FIRE, etc"
http://bluegenie.eu/smokealarm.asp
Back to top
 Alert Moderators
Lectrician
from United Kingdom
Thanked: 187 times
PostPosted: Sun Apr 27, 2008 8:19 am Reply with quote
Press and hold the test button for ten secs on the smoke. If that doesn't work, most likely the battery.
Back to top
 Alert Moderators
mdbalson
from United Kingdom
PostPosted: Sun Apr 27, 2008 1:50 pm Reply with quote
Do CFL's do that then when on 2w SW icon_question.gif As at home both of my landing lights are on 2w SW's, but they do not flash.
Back to top
 Alert Moderators
radsik
from United Kingdom
PostPosted: Sun Apr 27, 2008 3:18 pm Reply with quote
Done that a few times and it always works on a test, it is a mains one and it's connected to the flashing light so was not sure if that is related to it going off.
Back to top
 Alert Moderators
mattylad
from United Kingdom
Thanked: 80 times
PostPosted: Sun Apr 27, 2008 3:27 pm Reply with quote
I have this, but on the whole lighting circuit.
(all cfl's flash).
But it seems that although there is an earth in the fittings, roses etc, there is no actual aearth in the feed wire from the CU, so its floating!
(yet another job for me to fix).
Back to top
 Alert Moderators
Spark123
from United Kingdom
Thanked: 342 times
PostPosted: Sun Apr 27, 2008 3:39 pm Reply with quote
Depends on a few factors i.e. how the 2 way lighing is wired and length of the switch wire cables.
If anyone wants to try an experiment to see if this overcomes it: http://www.diynot.com/forums/viewtopic.php?p=726034#726034
Back to top
 Alert Moderators
Spark123
from United Kingdom
Thanked: 342 times
PostPosted: Sun Apr 27, 2008 3:41 pm Reply with quote
(all cfl's flash).
Yeah, needs fixing asap if you have any metal fittings, light switches, back boxes etc.
Back to top
 Alert Moderators
mattylad
from United Kingdom
Thanked: 80 times
PostPosted: Sun Apr 27, 2008 3:45 pm Reply with quote
OH yes it does.
Back to top
 Alert Moderators
Goto page 1, 2  Next
Page 1 of 2
Jump to:
Kitchen Light flashing 19 820 Mon Jan 18, 2010 7:34 pm
Flashing Energy Saving Light with the light switch OFF 22 13640 Thu Dec 14, 2006 4:47 pm
3 gang 2 way light switch flashing issue 8 160 Wed Sep 12, 2012 10:03 pm
Flashing Light 3 100 Sat Aug 04, 2012 10:29 pm
Bathroom light flashing? 7 580 Thu Jan 22, 2004 6:36 am
DIYnot
