BigJ
Joined: 24 Jul 2008 Posts: 7 Location: Staffordshire, United Kingdom
Posted: Sat Jan 17, 2009 6:43 pm |
As above - leaking on RH Hydro Block Assembly when hot water is turned on. Do they do a repair kit for the gasket or new assembly anywhere - cant seem to find one
cheers
BigJ |
Gas2Air
Joined: 02 Aug 2004 Posts: 655 Location: United Kingdom Thanked: 12 times
Posted: Sat Jan 17, 2009 6:55 pm |
Is it the flow switch near the pump? If so yes you can change the diaphragm, take the 4 screws out the brass housing and replace, you can also get the housing and diaphragm complete i think. Not sure what part number is though. |
BigJ
Posted: Sat Jan 17, 2009 7:00 pm |
| Gas2Air wrote: | | Is it the flow switch near the pump? If so yes you can change the diaphragm, take the 4 screws out the brass housing and replace, you can also get the housing and diaphragm complete i think. Not sure what part number is though. |
yes mate thats the one - cant seem to find the part no though - will try again now to locate new diaphragm otherwise to the merchants on Monday...cheers for that |
BigJ
Posted: Sat Jan 17, 2009 7:15 pm |
Hi Gas2Air - just for further reference if you ever need the product code for the diaphragm its S801191 - sorted now, will still have to wait till Monday to order... |
