Celing double pole switch
Law
24 Nov 2004
Hi.I work in a hotel and a guest said the electric shower in her room was working and then it cut out suddenly with no power or signs of life. I\\\'ve looked at the fuse box on that floor and nothing seems to be amiss and the lights in that bedroom and bathroom are working.
The red light on the pull chord switch to supply electricity to the shower isn\\\'t on(despite the plastic tag saying it is) so I am assuming there is a fuse gone. Being no electrician, can anyone please advise on what to look for or to do in trying to get this shower going again.
Many thanks in advance for any help.
Lawrence
because you are in a commercail premmises (hotel) you will not be insured should anything go wrong :cry: best call an electrician
Same thing's happened to me at home
Shower was working, then it suddenly cut out.
The red light on the pull cord switch has gone out, and so there's no power getting to the shower ... I've checked the fuse box and the fuse is still fully intact.
I'm *guesing* therefore, that it's the switch. Any advice/ideas on how I can get it working? Do I need to replace the switch, or is there maybe an internal fuse or something I can replace?
Remove the fuse.
Take the cover off the switch and carefully use your multimeter to check that the supply is dead. Check for loose connections, signs of damage etc. If the cable insulation shows signs of overheating then you must cut it back to an undamaged position.
If there's nothing apparently wrong, temporarily replace the fuse and carefully use your multimeter to check that the supply is reaching the switch.
If it is, then the switch is b*ggered. If not then you have a problem elsewhere.
Possibly. One indication - does it still have the same "feel" when you pull the cord?
There are no fuses in it.
Cheers for the advice, I had removed the cover last night and there doesn't appear to be any visible damage to the wiring ... that's another reason I felt it might be the switch.
It was just process of elimination really given the light isn't coming on any more when the switch is pulled ... makes me suspect it's either the switch or something between that and the fusebox at least.
In the summer, I replaced the shower for a 10.5Kw model, having checked the supply cable is 10mm, all seemed OK ... however the switch is older, and has no visible indication of the rating, so I suppose there's potential it's too low for the new shower - I assume any replacement should be 45a?
It still feels pretty much the same - though the cord has been known to be tempramental in the past: sticking in the 'on' or 'off' positions etc.
Thanks again, will give it a go....
