DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Removing a kitchen sink without damaging worktop
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
SaraD21
from United Kingdom
PostPosted: Thu Mar 05, 2009 12:49 pm Reply with quote
Hello,
I would like some advice please on how to remove a stainless steal sink in my kitchen sink without possibly damaging the worktop surface.
I have just bought the house and I like the kitchen units the previous owner installed but the only problem is that the sink is too small and it is also badly stained and discoloured…
I would like to remove it and replace it with a new bigger sink (may be ceramic) but without having to replace the worktop if at all possible.
Does anyone have advice on how to best tackle this?
Thank you
Sara
Back to top
 Alert Moderators
mogget
from United Kingdom
Thanked: 108 times
PostPosted: Thu Mar 05, 2009 1:14 pm Reply with quote
You probably won't be able to clean up the edges of the old hole, but if the new sink requires a bigger hole you should be OK.
What I would do is to buy a roll of gaffer tape / duct tape etc and cover the worktop around the sink so that there's about 1/4 inch of bare worktop showing around the sink.
Then I'd undo any clips under the sink, along with all the plumbing. After that take a thin sharp knife and see if you can slide it under the edge of the sink to cut the sealant. You can also use a screwdriver to help lever the old sink up. Carry on cutting and levering until the sink is free and remove gaffer tape.
Be careful of sharp edges both on the knife and on the sink!
I am a householder not a professional.
Back to top
 Alert Moderators
SaraD21
from United Kingdom
PostPosted: Fri Mar 13, 2009 9:26 am Reply with quote
Thank you very much!
Sara
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
How to fit bath taps without damaging the bath??!! 3 140 Wed Feb 26, 2014 11:51 am
Mira 88 shower control - Removal without damaging tiling 9 680 Tue Jan 12, 2010 7:11 pm
Removing Sink from worktop 3 400 Thu Aug 24, 2006 12:17 am
Fixing kitchen sink to worktop 7 140 Fri Jul 05, 2013 7:18 pm
Kitchen sink not set into worktop 2 380 Sun May 24, 2009 6:59 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
