the capping is only to protect the cable from plasterers and as long as they have not damaged cable it is OK.
Oh god not that old chestnut again
! Capping of any sort is not required by the regs. & there is certainly nothing in the regs that states it's required "to protect against damage by a plastreres trowel"; & believe me I've checked. IMO capping is good practice & should be compulsory, it keeps the cables together & covered in one place so they can be plastered over; you can't easily plaster over loose dangling ables
! IMO, steel capping is infinitely better than plastic simply because it gives some protection against future, DIY dick heads with a drill & a masonry bit looking to fix/hang something up. Masonry bits don't like going through steel unless you really force them & the extra time steel capping will give may just save the cables if said dick head realises there may be a problem but capping is NOT NECESSARY TO POREVENT A PLASTERER DAMAGING THE CABLES. I’ll say it again, there is no way on this earth that a plasterer is going to damage twin & earth cable with a plastering trowel, it’s a complete urban myth; we don't hack at everything in sight with the edge of a trowel FCS, do all sparks think we are heathens.
