DIYnot
Local | Network
   DIYnot > Forums
Local | Network
How to get my transit door open
Post new topic   Reply to topic    DIYnot.com Forum Index > Car Repairs / Maintenance
Author Message
tommyl18
from United Kingdom
Thanked: 29 times
PostPosted: Mon Nov 16, 2009 9:23 pm Reply with quote
Hi ive got a ford transit lwb r reg and the drivers door has jammed and wont open from the inside or outside we have taken the door card off from the inside and the barrel is working fine the door handles and linkages are ok it seems to be the latch has either seized or is broke we have drilled the rivets and removed the metal plate behind the barrel to get axcess to the latch but the latch has a case around it and we cannot remove it because the screws for the latch are obviously on the side of the door which we cannot get access to without opening the door any ideas how to remove the latch and get the door open ?
Back to top
 Alert Moderators
dinou
from Australia
PostPosted: Thu Jun 02, 2011 2:44 am Reply with quote
[quote="tommyl18";p="1409334"]Hi ive got a ford transit lwb r reg and the drivers door has jammed and wont open from the inside or outside we have taken the door card off from the inside and the barrel is working fine the door handles and linkages are ok it seems to be the latch has either seized or is broke we have drilled the rivets and removed the metal plate behind the barrel to get axcess to the latch but the latch has a case around it and we cannot remove it because the screws for the latch are obviously on the side of the door which we cannot get access to without opening the door any ideas how to remove the latch and get the door open ?[/quote
I have the same problem how did you fix it?
Back to top
 Alert Moderators
10phil79
from United Kingdom
Thanked: 2 times
PostPosted: Thu Jun 02, 2011 9:33 pm Reply with quote
hey - I had same problem with my golf. In my case, the deadlock had siezed - in the locked position.
i managed to drill through the lock housing from inside the car and "wind back" the worm and peg mechanism to un-lock the lock.
of course - most probably a different setup in the ford but thought this may help you in some way.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Car Repairs / Maintenance All times are GMT
Page 1 of 1
Jump to:
Nissan Micra. Flat battery can not open door 3 6340 Thu Jan 01, 2009 12:55 pm
Laguna Door showing open.... its not... help please 4 80 Sun Feb 03, 2013 9:20 am
door won,t open on megane 8 1520 Fri Oct 03, 2008 11:29 am
vauxhall vivaro door open warning light on 4 1800 Wed Feb 25, 2009 7:08 pm
ford focus 56 cant open bonnet 8 7500 Wed Dec 30, 2009 3:25 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
