DIYnot
Local | Network
   DIYnot > Forums
Local | Network
french upvc door won't lock
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors
Author Message
dave2086
from United Kingdom
PostPosted: Wed Jan 13, 2010 9:20 pm Reply with quote
my french upvc door won't lock when closed,all the hooks and rollers appeaer ok and if handle lifted as normal key won,t turn to locked position,allthough it all works when door is open so nothing broken i think .It happened when the snow came -any help have tried to lubricate it suspect the lock fouling but can't see when door closes?
Back to top
 Alert Moderators
crank39
from United Kingdom
Thanked: 391 times
PostPosted: Wed Jan 13, 2010 9:44 pm Reply with quote
Simple......the handle isnt going right up, it may seem it is but its stopping minutley short. The doors have moved out of sync with each other, either shrunk in the cold (very likely) and have moved apart from each other OR one or both have dropped.
Look for adjustment on your hinges for adjustment
Flag hinge...http://www.dgsupplyline.co.uk/results.php?category_id=11&sub_category_id=80&range_id=229#
Click to enlarge the middle picture to show how to adjust, check the vertical allen key and look at your hinge.
Pendulam hinge...http://www.dgsupplyline.co.uk/results.php?category_id=11&sub_category_id=80&range_id=397
Click to enlarge first picture, note the 2 phillips screws, these turn a quarter of a turn each way, turn both equally, these move the door back and forth
Butt hinge...http://www.dgsupplyline.co.uk/results.php?category_id=11&sub_category_id=80&range_id=232
Click to enlarge first picture, see those 2 silver hinge pins, these need turning by using a small allen key in top and bottom of each pin, be sure to loosen the little grub screws though, these stop the pins coming out so will stop them turning too, these hinges are quite old now and cr*p.
Back to top
The following user says thank you to crank39 for this useful post:
dave2086 (13 Jan 2010)
 Alert Moderators
HandyHands
from United Kingdom
Thanked: 16 times
PostPosted: Wed Jan 13, 2010 10:07 pm Reply with quote
Sound advice above.
Also worth removing the keeps from the frame and replacing one-by-one, testing the locking process after each replacement, to help identify which is fouling.
Back to top
The following user says thank you to HandyHands for this useful post:
 Alert Moderators
crank39
from United Kingdom
Thanked: 391 times
PostPosted: Wed Jan 13, 2010 10:27 pm Reply with quote
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors All times are GMT
Page 1 of 1
Jump to:
Upvc french door broken handle(?) and /or lock 4 5020 Sun Apr 06, 2008 12:50 pm
Lock hidden in UPVC French doors 4 120 Fri Oct 12, 2012 9:40 am
UPVC FRENCH DOORS WONT LOCK 11 880 Mon Dec 06, 2010 11:15 am
uPVC French Window Lock Sticking 2 60 Sun Apr 06, 2014 7:13 pm
Upvc French Window - Key Snapped Off In Lock. HELP! 11 760 Sat Feb 07, 2009 7:28 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
