DIYnot
Local | Network
   DIYnot > Forums
Local | Network
28mm gas pipe ugrade required for 35kw boiler ?
Goto page 1, 2  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
gavm
from United Kingdom
PostPosted: Tue May 04, 2010 9:48 pm Reply with quote
Hi i recently bought a broag remeha avanta 35c bolier and have just had a plumber round for a quote to install ..
He has advised i get a bigger gas supply pipe of 28mm from the meter to the boiler cupboard which i currently have 22mm pipework... The meter is approximately 10m from from where the current boiler is situated... Obviously this is going to involve more labour and materials with ripping up the floor etc to make good the upgrade..
He says i neeed a bigger supply because the boiler is a 35kw and also because im running a gas hob with single gas oven too...
Can someone please confirm this to be true or is the 22mm pipework i already have adequate to do the job as i had another quote from a heating engineer and he did not mention the pipe upgrade needing to be done...
Thanks in advance Gavin
Back to top
 Alert Moderators
keighern
from United Kingdom
Thanked: 1 time
PostPosted: Tue May 04, 2010 9:57 pm Reply with quote
depends on number of factures. Needs correct pipe sizing calculations doing to ensure sufficient flow of gas to appliances. To answer your question all installs are different so no definitive answer unless viewed and calculated.
Back to top
 Alert Moderators
greemyamochop
from United Kingdom
Thanked: 22 times
PostPosted: Tue May 04, 2010 10:32 pm Reply with quote
Maybe that the second engineer is not as good as your first but either way the only way to be sure is by doing correct calculations with the consumption required for all appliances.
When its worked out properly it may mean that only some of the pipework needs to be altered but i would say there is a decent possiblity it needs upgrading.
Mention it to the second engineer, if hes a decent installer hell do the calculations for you, i would if it meant getting the job!!
Back to top
 Alert Moderators
newgas
from United Kingdom
Thanked: 363 times
PostPosted: Tue May 04, 2010 10:36 pm Reply with quote
22mm at 10 mtrs with a hob and gas oven on might be OK but in winter say when the demand is high for heating and you are using both hob and oven with the heating on then the gas pressure is reduced to all appliances because it might not be sufficient for max usage.
That is what you have to work out the MAX usage of appliances and the the size / length of pipe will tell you what the pressure loss will be.
Undersized pipework can cause problems in your appliances and they can potentially become dangerous.
Your plumber could just put in a couple of lengths of 28mm from the meter to the 22mm and that should be OK but I'm going with what youve said, but then I'm not there. icon_rolleyes.gif
Back to top
 Alert Moderators
mickyg
from United Kingdom
Thanked: 3218 times
PostPosted: Tue May 04, 2010 11:14 pm Reply with quote
but 10m plus elbows/tees an oven and hob sounds like a 28mm jobby to me. Some modern 5 burner hobs are as much as 12kw, add your oven and your easily in 28mm territory.
if you can get your head around it, you can calculate it using this guide. you will need to know the "input"of each appliance being installed.
http://www.ukcopperboard.co.uk/literature/pdfs/Installation-Tips/Domestic-gas-planning-and-sizing.pdf
Back to top
The following user says thank you to mickyg for this useful post:
westeleven (5 May 2010)
 Alert Moderators
gavm
from United Kingdom
PostPosted: Wed May 05, 2010 5:43 am Reply with quote
Thanks very much guys for all your input..
After reading your comments i am leaning towards the 28mm having to be used now.
Cheers Gavin
Back to top
 Alert Moderators
newgas
from United Kingdom
Thanked: 363 times
PostPosted: Wed May 05, 2010 5:40 pm Reply with quote
Back to top
 Alert Moderators
Boilerman2
from United Kingdom
Thanked: 961 times
PostPosted: Wed May 05, 2010 6:21 pm Reply with quote
unless the boiler is VERY close to the gas meter a 28mm supply will nearly always be required IMHO icon_wink.gif
Back to top
 Alert Moderators
Happyplumber
from United Kingdom
Thanked: 690 times
PostPosted: Wed May 05, 2010 6:23 pm Reply with quote
pipe sizeing is critical to any band A boiler so its good idea to do a proper calculation and make sure its the correct size
Back to top
 Alert Moderators
Boilerman2
from United Kingdom
Thanked: 961 times
PostPosted: Wed May 05, 2010 8:16 pm Reply with quote
signed Little John
Back to top
 Alert Moderators
dreadnoughtheating
from United Kingdom
Thanked: 322 times
PostPosted: Fri May 07, 2010 7:55 pm Reply with quote
And yet again (I say this to the regular CC guys answering this thread - you know who we are...) we have the customer supplying the appliance, and querying the technical knowledge of his installer..... should we as GasSafe installers presumably with a living to make, be answering any such queries?
Answer on a ping-pong ball please
DH
Back to top
 Alert Moderators
ianniann
from United Kingdom
Thanked: 74 times
PostPosted: Fri May 07, 2010 8:34 pm Reply with quote
No way! Meet in secret under a full moon, ban those NVQs that any fool can study for, and only let the first born son of seven generations of gas fitters apply to Gas Safe icon_wink.gif
Back to top
 Alert Moderators
simond
from United Kingdom
Thanked: 273 times
PostPosted: Fri May 07, 2010 8:50 pm Reply with quote
I don't think there is a problem with helping people with a question, whether it is gas related or not.
However I would question the wisdom of the OP buying the boiler and then trying to get someone to fit it.
Very few dedicated installers (eg: individuals/companies who specialize in boiler fitting) will entertain fitting a customer supplied boiler. I get calls regularly from people who are getting quite desparate having bought a boiler on the internet and can't find anyone prepared to fit it.
If you want to buy your own boiler I suggest you find an installer first - this might restrict you to a very small number of Gas Safe Registered contractors indeed. Certainly would take me out of the picture.
Back to top
 Alert Moderators
johnjohnscg
from United Kingdom
PostPosted: Sun Jun 05, 2011 9:41 am Reply with quote
What should happen when a gassafe installer hasn't done the calcs as requested for a new install, then the customer's done their own and found the pipe to be undersized after installatio . Who's out of pocket for the upgrade pipe materials?
Back to top
 Alert Moderators
picasso
from United Kingdom
Thanked: 1263 times
PostPosted: Sun Jun 05, 2011 9:57 am Reply with quote
the installer will end up out of pocket, its the installers responability to ensure its done properly,you cannot blame the customer for not doing your job the way it should be done.
Back to top
The following user says thank you to picasso for this useful post:
johnjohnscg (5 Jun 2011)
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
New Boiler installation central heating ugrade 10 840 Thu Sep 27, 2007 11:50 am
Should I buy Viessmann Vitodens 200 35kw combi boiler? 14 37600 Wed Nov 11, 2009 2:25 pm
Plumber specced 30KW system boiler, online calc says 35KW 18 4820 Thu May 27, 2010 11:13 am
Veissman Vitodens 100 W 35kw Combi boiler gas connections 13 160 Mon Aug 29, 2011 5:57 pm
(unspecified) Viessmann 35kw combi fault 3 180 Mon Dec 06, 2010 10:18 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
