DIYnot
Local | Network
   DIYnot > Forums
Local | Network
downlights from 13 amp connection unit
Author Message
crooner
from United Kingdom
PostPosted: Fri May 28, 2010 6:35 pm Reply with quote
Hi, i want to fit down lights downstairs in kitchen ceiling, i have a 13 amp socket that will never be used as it is jammed behind a kitchen unit,i can get access to the cable's from the back quite easily,and fit connection unit higher up the wall for access, so can i change 13amp socket to a 13amp connection unit,then run a 1.5 cable to lights,
Back to top
 Alert Moderators
BigJon
from United Kingdom
Thanked: 25 times
PostPosted: Fri May 28, 2010 6:54 pm Reply with quote
I dont see why not, presuming its a switched fused connection unit your going to be fitting.
Will you be burying the cables, do you know if you have RCD protection on said circuit?
Back to top
The following user says thank you to BigJon for this useful post:
crooner (29 May 2010)
 Alert Moderators
crooner
from United Kingdom
PostPosted: Fri May 28, 2010 7:32 pm Reply with quote
bigjon, yes it is a switched fuse unit, i'm not sure if i have RCD protection the fuse box have switches,the cables run down to a 13 amp socket i was going to cut these cables and run to the fused connection unit,
from what i have read on this site this is okay if the fused connection unit was a spur, but i was unsure because it would be on the ring circuit as i cant get access to front of 13 amp socket, i can only get into the cables that go into the back of socket
Back to top
 Alert Moderators
spark1
from United Kingdom
Thanked: 16 times
PostPosted: Fri May 28, 2010 8:53 pm Reply with quote
would these downlights be 230 volt or 12 volt type ?
Back to top
 Alert Moderators
crooner
from United Kingdom
PostPosted: Sat May 29, 2010 12:15 am Reply with quote
Hi spark1, i was thinking of putting in 230volt they will go into plaster board ceiling which i will be getting plastered,(no more than 2 50 watt's plenty of room in ceiling,by the way i have decided to put a 13 amp socket above the one i cant access & just run a fused connection unit to lights,can you advise me on lights they are not for show,someone in the family is visually impaired
Back to top
 Alert Moderators
PrenticeBoyofDerry
from United Kingdom
Thanked: 1930 times
PostPosted: Sat May 29, 2010 6:27 am Reply with quote
The 13 amp socket should not be jammed behind a kitchen unit, they should be easily accessesible. So if at any time they did need to be inspected and tested this could be done.
I suggest the socket is moved, so it is accessible.
A fused connection unit can be installed to this, you could use a switched FCU as this can then be used as a functional switch, if not you would need to then drop a switch cable down to operate the lights. The FCU would need to be down fused to a suitable rating.
When fitting downlights you must ensure that you have adequate ventilation around the fitting and that their use does not breech any fire regulations.
Back to top
The following user says thank you to PrenticeBoyofDerry for this useful post:
 Alert Moderators
wingcoax
from United Kingdom
Thanked: 157 times
PostPosted: Sat May 29, 2010 11:39 am Reply with quote
What seems to have been missed so far is that you cannot use a 13A fuse on the lighting circuit. You will have to fit a 3A fuse in the FCU in order to comply with regs.
Back to top
The following user says thank you to wingcoax for this useful post:
 Alert Moderators
PrenticeBoyofDerry
from United Kingdom
Thanked: 1930 times
PostPosted: Sat May 29, 2010 12:10 pm Reply with quote
Back to top
 Alert Moderators
wingcoax
from United Kingdom
Thanked: 157 times
PostPosted: Sat May 29, 2010 12:17 pm Reply with quote
icon_cool.gif[/quote]
Back to top
 Alert Moderators
Page 1 of 1
Jump to:
GU10 Downlights earth connection 5 820 Fri Apr 11, 2008 6:40 pm
Switched/Fused Connection Unit & Double Socket 2 1220 Sat Dec 31, 2005 5:05 pm
Connection unit/junction box 16 960 Tue Nov 29, 2005 6:58 pm
fuse connection unit 3 340 Thu Oct 27, 2005 2:19 pm
COOKER MAIN CONNECTION TO CONSUMER UNIT 2 680 Fri Nov 10, 2006 9:26 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
