Currently my garage has one light powered through a 5A RCD, with one switch. I'd like to convert this to 4 x (2x 70W T8) 6ft lamps, operating off two switches at either end of the garage. I also need to wire up a seperate 2 x single 70W T8 for the attic part of the garage. Total wattage will be 700W. It's all wired presently with 1.0m twin and earth.
I've decided to connect up 2 x 2way2 gang switches to cover both circuits.
These are my questions please.
1) I'm assuming 1.00m twin and earth throughout will still support the total 700 wattage? Is this satisfactory?
2) Will I have to uprate the fuse in the RCD (I work it to be a max of about 3A?)
3) My main question is, since upstairs and downstairs circuits are controlled from different circuits can they both be connected through the same 5AMP fuse in the RCD?
4) and if so which is the best way to send a live to the second 2way switch, either through a totally seperate wire from the fuse or can I just connect the live across from one switch to the other ie jump?
Hope this all makes some sense, as you can tell I'm no electrician
