Is it acceptable.. well no is the simple answer.. clean it or replace the rebar.. either that or get specific written instruction from the SEWe've been lashing the re-bar with mould oil on a job at the moment and some areas form a critical part of the structure.
Is this acceptable?
Many Thanks.
Yes.Are you an SE Static?
I would suggest that you get hold of some degreasing agent and try and undo what you have done!
The Aberdeen Group tests were
made with 100% contaminant coverage
of the reinforcing steel, they
represent the worst possible case.
Under these severe conditions, the
contaminants didn’t adversely affect
bond.
the steel rods will not break, but they may stretch beyond design tolerances and cause other safety critical problems.
