DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Extra sockets in garage and additional power to patio
Author Message
stuy_99
from United Kingdom
PostPosted: Mon Mar 28, 2005 5:43 pm Reply with quote
I am looking to extend the number of double sockets in my garage and continue into the garden. I have a consumer unit in the garage already as the house is relatively new. I would like to add at least one double inside the garage and also supply power to the patio for another double and some garden lighting..............................Any ideas would be gratefully accepted
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 24 times
PostPosted: Mon Mar 28, 2005 5:46 pm Reply with quote
it may seem obvious, but for outside socket you will nee to use weather proof sockets.
as for the garden lighting why not use low voltage and put the transfomer / switch / timer/ whatever inside the garge and plug it in.
Back to top
 Alert Moderators
jvanhoof
from United Kingdom
PostPosted: Mon Mar 28, 2005 5:47 pm Reply with quote
Not sure what you mean about anyone having an idea...
You need to run a ring around the garage and put all the double sockets into that ring, then into the garden you could run a spur to the weather proof socket you will need to install or extend the ring into the garden.
Does this help you ??
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 24 times
PostPosted: Mon Mar 28, 2005 5:50 pm Reply with quote
icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif
you giving advice, and you are the one with a problem
Back to top
 Alert Moderators
jvanhoof
from United Kingdom
PostPosted: Mon Mar 28, 2005 5:53 pm Reply with quote
I have never thought I knew everything, only fools would think that...
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 24 times
PostPosted: Mon Mar 28, 2005 5:55 pm Reply with quote
but you offer electrical "advice" that you do not understand the question (you said so, not me) and you can not figure your own problem.
welcome to the forums
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 1337 times
PostPosted: Wed Mar 30, 2005 12:26 am Reply with quote
No, he doesn't, a radial is perfectly good.
You might think it's a good idea to try and wire a ring circuit in SWA, but others would not agree...
Back to top
 Alert Moderators
plugwash
from United Kingdom
Thanked: 125 times
PostPosted: Thu Mar 31, 2005 2:51 am Reply with quote
can't see why its a bad idea with 2.5mm or 4mm SWA in decent sizes accesories
im sure i've seen it done with metalclad sockets in places like big exibition halls (no water but lots of big items being moved around that could damage stuff)
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 1337 times
PostPosted: Thu Mar 31, 2005 9:19 am Reply with quote
But were they wired as a ring?
Back to top
 Alert Moderators
plugwash
from United Kingdom
Thanked: 125 times
PostPosted: Thu Mar 31, 2005 11:25 pm Reply with quote
there was certainly more than one cable in each socket dunno if it was ring or radial
can't see any difference from a difficulty of installation pov between wiring a ring or a radial in swa
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 1337 times
PostPosted: Fri Apr 01, 2005 9:00 am Reply with quote
Apart from running it back and terminating it again. Really can't see the point...
Back to top
 Alert Moderators
Page 1 of 1
Jump to:
adding a light unit on patio. 2 440 Wed Apr 25, 2007 2:35 pm
Patio Lights 8 1100 Tue May 15, 2007 7:08 pm
Under patio wiring 7 860 Tue Apr 10, 2007 2:39 pm
patio lights from indoor switch 10 1480 Wed Feb 28, 2007 1:08 pm
Patio lights 4 660 Sun Aug 13, 2006 7:20 pm
DIYnot
