DIYnot
Local | Network
   DIYnot > Forums
Local | Network
What causes 'metallic' taste in water?
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
squeaky
from United Kingdom
Thanked: 189 times
PostPosted: Wed Aug 04, 2010 6:37 pm Reply with quote
Hi all.
Does anyone have any ideas on what may be causing the following?-
I have a customer who says that their tap water has a metallic taste. This has been happening for about four months after having a new washing machine fitted. They contacted their water supplier who were convinced that it was to do with the new washing machine and suggested fitting check valves.
I have since fitted check valves to both the washing machine and the dishwasher supplies but the problem has not gone. Apparently when the water is boiled in the kettle, it tastes even worse.
Also, they were thinking of fitting a water filter kit with replaceable cartridge. Does anyone know if theses are any good?
Thanks v much.
Back to top
 Alert Moderators
kevindgas
from United Kingdom
Thanked: 467 times
PostPosted: Wed Aug 04, 2010 6:43 pm Reply with quote
the supply pipe is it metal? is there any mallable iron pipe in the building? if the pipe is rotting out it will give this taste.
Back to top
 Alert Moderators
squeaky
from United Kingdom
Thanked: 189 times
PostPosted: Wed Aug 04, 2010 6:51 pm Reply with quote
Hi kevindgas.
All the pipe work is copper - house built in the 60's. I infact fitted the kitchen for them about six years ago and ther was no problem until now. I'm pretty sure there are no iron pipes anywhere. unless its outside the house maybe. I will check this with them.
Back to top
 Alert Moderators
Whitespirit66
from United Kingdom
Thanked: 606 times
PostPosted: Wed Aug 04, 2010 7:37 pm Reply with quote
I had an identical job to yours in Bristol. Cold water came in through floor in corner of kitchen, tee'd off to kitchen cold tap and wash machine/dish washer before rising to ceiling to supply rest of house.
She contacted the water co, they said put check valves on wash machine/d washer, and replace machine supply hoses.
Back to top
 Alert Moderators
heatingman
from United Kingdom
Thanked: 112 times
PostPosted: Wed Aug 04, 2010 8:04 pm Reply with quote
the problem arises when plastic or rubber parts in fittings or appliances start to react with the chlorine in the water, it can produce phenolic compounds such as TCP. Boil the water, if taste still there it is a phenolic compound. Different people describe the taste or odour as TCP, disinfectant, medicine, metal, bitter or chemically. Common cause are kettles (gaskets), flexible hoses & tap washers.
Back to top
The following 5 users say thank you to heatingman for this useful post:
squeaky (5 Aug 2010), Onetap (5 Aug 2010), Nige F (5 Aug 2010), daneski88 (4 Aug 2010), kevindgas (4 Aug 2010)
 Alert Moderators
kevindgas
from United Kingdom
Thanked: 467 times
PostPosted: Wed Aug 04, 2010 9:21 pm Reply with quote
well you learn something every day!!
Back to top
 Alert Moderators
daneski88
from United Kingdom
Thanked: 13 times
PostPosted: Wed Aug 04, 2010 9:27 pm Reply with quote
So, you'll never get a cold nor sore throat again!
Back to top
 Alert Moderators
nelectric
from United Kingdom
PostPosted: Thu Aug 05, 2010 8:29 am Reply with quote
So most likely culprit in this case then would seem be the flexible hoses to the washing machine? Is there any evidence that different washing m/c manufacturers use different plastic compounds in their flexible pipes?
@heatingman, does this reaction happen with new plastic or rubber items, or just old ones? Can you give us a source (link to) more information? Am interested in finding out more about this.
Back to top
 Alert Moderators
ollski
from United Kingdom
Thanked: 63 times
PostPosted: Thu Aug 05, 2010 8:55 am Reply with quote
Because of my lead water main I use a reverse osmosis unit for my ingested water, have a TDS of over 600ppm into the unit and 0 - 1 coming out.
Back to top
 Alert Moderators
Onetap
from United Kingdom
Thanked: 187 times
PostPosted: Thu Aug 05, 2010 11:47 am Reply with quote
I didn't know that; I do now!
A Google for "phenolic tcp mettalic taste water" found;
http://www.anglianwater.co.uk/household/water-quality/facts/tcp/
See also the acrobat download link at the bottom of that page.
PS Non WRAS-approved washing machine hoses and washers seem to be the main culprits. There have also been incidents of contamination from no-name cheapo flexible tap connectors, so it may be worthwhile checking any of those.
Back to top
 Alert Moderators
squeaky
from United Kingdom
Thanked: 189 times
PostPosted: Thu Aug 05, 2010 9:27 pm Reply with quote
Thanks for your replies everyone. This gives me more to work on. I will come back to this thread if I manage to solve the problem as I can see that a few of would be interested in the results
Back to top
The following user says thank you to squeaky for this useful post:
daneski88 (5 Aug 2010)
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
metallic bottle traps for sink 3 460 Mon Feb 02, 2004 7:02 pm
Bad taste of TCP in water. 12 560 Fri Dec 16, 2011 12:01 am
New kitchen mixer making water taste funny? 5 100 Fri Feb 21, 2014 8:01 am
water taste from taps 3 100 Mon Jun 20, 2011 7:29 pm
Rubber taste in cold water - unvented cylinder system 8 240 Tue Feb 19, 2013 9:36 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
