DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Riello Hydraulic Jack replacement
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
Suffolk_Simon
from United Kingdom
PostPosted: Thu Oct 07, 2010 9:25 am Reply with quote
Just wondering what the procedure is for changing a leaking hydraulic jack on a Riello G5 burner? un-mounting it from the burner is no problem, but I'm wondering how you disconnect the oil pipe at the jack end. There appears to be a knurled nut on the top but this seems to be stuck solid. What tool would you use? I'm ok with the water side of things but am very wary of oil lines!
Edit: looking at a few posts on here and on other forums looks like I might be better off removing the jack and shutter altogether and blanking of the port on the pump... What would you do?
Simon
Back to top
 Alert Moderators
adlplumbing
from United Kingdom
Thanked: 312 times
PostPosted: Thu Oct 07, 2010 10:43 am Reply with quote
if this is the type what digs up roads i think repost it in tool section icon_question.gif
Back to top
 Alert Moderators
Terrywookfit
from Antarctica
Thanked: 348 times
PostPosted: Thu Oct 07, 2010 1:15 pm Reply with quote
Use Gland nut pliers on the knurled section, The hex head will round off.
If the boiler is balanced flue you may get fumes when it turns off, if removed.
Back to top
The following user says thank you to Terrywookfit for this useful post:
Suffolk_Simon (7 Oct 2010)
 Alert Moderators
wiss
from United Kingdom
Thanked: 3 times
PostPosted: Thu Oct 07, 2010 10:50 pm Reply with quote
You can i think still get replacment seals for the oil rams
Back to top
 Alert Moderators
Suffolk_Simon
from United Kingdom
PostPosted: Thu Oct 07, 2010 11:07 pm Reply with quote
I think I'll replace the entire ram - they can be had cheap enough on line. Have got the old one off now, so it's a two minute job.
Simon
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Britony 80se hydraulic block 2 400 Mon Sep 24, 2007 10:21 pm
sink and dishwasher not draining (hi-jack split) 3 2760 Thu May 01, 2008 7:00 pm
jack-all pressure in my shower.. will a pump fix the problem 4 720 Wed Jul 12, 2006 4:46 pm
Riello burner struggling to ignite 33 380 Wed Jan 04, 2012 12:31 am
Riello 40 G5X won't start 12 160 Tue Nov 15, 2011 8:25 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
