DIYnot
Local | Network
   DIYnot > Forums
Local | Network
LG 1402FDS Error code AE
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances
Author Message
rjb2001
from United Kingdom
PostPosted: Thu Dec 30, 2010 10:58 am Reply with quote
LG 1402FDS Washer
Came back off holiday to find washer cw supply hose had split due to the cold weather so garage was rather soggy - have fitted a new hose and now the washer shows error code 'AE' which according the instruction manual has the following fix: Symptom - Water Leak, Action - Call Service.
Before I go in the back of the m/c has anybody any further info?
Cheers,
Rob.
Back to top
 Alert Moderators
zipper
from United Kingdom
Thanked: 505 times
PostPosted: Thu Dec 30, 2010 12:09 pm Reply with quote
It indicates a leak has activated the flood protection device in the base. Lean the machine forward (or backward) & see if water runs out of the base. If it does you may be able to restart...but the source of the leak will need to be identified & fixed. I think it would be wise to remove the lid & check if the inlet valve has popped first.
Back to top
The following user says thank you to zipper for this useful post:
rjb2001 (30 Dec 2010)
 Alert Moderators
rjb2001
from United Kingdom
PostPosted: Thu Dec 30, 2010 5:03 pm Reply with quote
icon_biggrin.gif Thanks for that, just got home from work and have tipped it forward on a couple of wood blocks and have got quite a puddle out of it - will leave it for a couple of hours to drain and then try again - the flexible hose had bust at the top near where it joins onto the valve on the copper piping and was spraying the back of the washer with water so I'm hoping it's just a consequence of that and not the inlet valve! (trying to avoid taking it apart until weekend). Will update later....
O/T - Our two local B&Q's had no blue washer hoses - one didn't have any left and I bought the last one at the other last night and neither had any pipe insulation left!!
Back to top
 Alert Moderators
zipper
from United Kingdom
Thanked: 505 times
PostPosted: Thu Dec 30, 2010 5:55 pm Reply with quote
Perhaps it might be an idea to remove the lid & back cover to help get rid of any residual dampness...then when you fire it up again you'll be able to check if anything else is leaking before it can do any damage. B & Q must have made a fair lump selling washer hoses after all the cold weather. One of these things is handy to have in your garage in the winter time http://cgi.ebay.co.uk/180W-4-1222mm-TUBULAR-HEATER-GARAGE-GREENHOUSE-TH04-/280553286412?pt=UK_Home_Garden_Hearing_Cooling_Air&hash=item4152476b0c&afsrc=1 especially if your washer lives in there icon_biggrin.gif
Back to top
 Alert Moderators
rjb2001
from United Kingdom
PostPosted: Thu Dec 30, 2010 9:42 pm Reply with quote
I'm an electronics service engineer by trade so normally I would have been straight in there but I've drawn the short straw this year and have been on call so haven't really had time to get inside and the wife wants to do the holiday washing icon_wink.gif but good news anyway, I tried it on a quick wash cycle to see if there were any leaks and all was good so put it on a cotton wash to bump up the temperature and hopefully dry the thing out and it's just in it's last half hour of the cycle and no problems so far icon_biggrin.gif
Will probably open it at weekend but its got me out of a hole for the moment.
Will have to sort some kind of frost heater out if this is going to be an indication of things to come - trouble is it's a double garage so the thing is never going to knock off and don't want to put it too close to the washer in case it isn't sufficient and we have a repeat - will have to have a think.
Anyway thanks for the help - much appreciated.
PS
I was looking on the net for spares for this m/c just in case and couldn't find any suppliers (or I was using the wrong search terms, but used the model no. and 'inlet valve') - do you have any idea where to get spares from?
Back to top
 Alert Moderators
zipper
from United Kingdom
Thanked: 505 times
PostPosted: Thu Dec 30, 2010 11:54 pm Reply with quote
Good the machine is running again. I doubt if you will need a replacement inlet valve...if yours had popped because of frost damage then believe me you would have noticed it by now. However if you find you need one later then buy a universal type, you'll get one for a fiver or less http://shop.ukwhitegoods.co.uk/Washing+Machine+Parts/LG/Inlet+Valves.htm Just make sure to check the valve orientation & hose diameter (12 or 14mm). A "frost guard" heater wouldn't cost you the earth even if the thermostat never triped out. You'd probably get away with less than 250W for a double garage, it doesn't take that much icon_biggrin.gif
Back to top
 Alert Moderators
rjb2001
from United Kingdom
PostPosted: Mon Jan 03, 2011 2:05 pm Reply with quote
Had a look and everything looks ok inside.
Have ordered a tubular heater and will connect it up in conjunction with an adjustable froststat so shouldn't cost the earth to run (only 120W anyway, but didn't want it on 24/7/365)
Back to top
 Alert Moderators
zipper
from United Kingdom
Thanked: 505 times
PostPosted: Mon Jan 03, 2011 9:46 pm Reply with quote
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances All times are GMT
Page 1 of 1
Jump to:
Hotpoint Aquarius WF560 Front Load WM Error code 13 1880 Wed May 12, 2010 2:09 pm
haier tumble dryer error code E2 3 380 Tue Jul 20, 2010 4:50 pm
smeg df612fas code error 2 80 Sun Jan 09, 2011 9:47 pm
Hotpoint WDM960 Error code F-01 4 12940 Sat Jul 17, 2010 8:53 pm
E14 error code on Hoover wasing machine 3 9980 Wed Jul 07, 2010 8:56 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
