DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Russian to UK plug wiring
This topic originated from the How to page called Wiring a plug
Click here to return to the page called Wiring a plug.
  View previous topic :: View next topic
Author Message
ScanSpeak
from United Kingdom
Thanked: 0 times
PostPosted: Sun May 15, 2005 5:54 pm    Post Subject:
Reply with quote Thanks
I have a Russian calculator with mains supply. The two wires are not colour coded, when wiring them into a UK plug which wire goes where?
Thanks for your help.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
andy
from United Kingdom
Thanked: 0 times
PostPosted: Sun May 15, 2005 6:01 pm    Post Subject:
Re: Russian to UK plug wiring
more details needed... does it feed a transformer? is it direct from mains?is is it rated for 230V? is it class 1 or 2 (1: need earth, 2: double insulated, no earth)?
Back to top
 Alert Moderators
plugwash
from United Kingdom
Thanked: 15 times
PostPosted: Sun May 15, 2005 6:18 pm    Post Subject:
got a photo? unless its really crappy it sounds like you may be dealing with a wall wart type power adaptor which you can't just cut off and replace with a plug.
Back to top
 Alert Moderators
Big_Spark
from United Kingdom
Thanked: 0 times
PostPosted: Sun May 15, 2005 6:48 pm    Post Subject:
If you post me the core colours I will tell you which goes where.
Just for the information of others here, Russia and the entire former Soviet States all use 230V 50Hz ac supplies.
Many of the installations do not have an Earth connection and thus there is unlikely to be a requirement for one in the calculator, it is likely to be double insulated and the transformer in the Unit will be of the Isolating type.
Usually Russian equipment will have Red and Black cores, with Red being live and Black Neutral, however the Transformer will be a basic affaior so if the cores where connected in reverse the unit would still work and the suffer no ill consequences as a result.
__________________
I only do commercial and Industrial so Prescott can shove his Part P tax
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Mobile Phone Plug Wiring - Yellow & Black 9 440 Sat Jun 20, 2009 6:24 pm
Wiring A Spotlight From A Switch To A Plug 2 420 Sun Nov 18, 2007 9:40 pm
Wiring ceiling lights to a plug? 17 2940 Sun Nov 18, 2007 7:41 pm
Wiring 4inch Bathroom extractor to a plug 6 4300 Mon Apr 23, 2007 2:38 pm
wiring a plug! 11 740 Wed Apr 30, 2008 10:47 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
