agh81
Joined: 20 May 2005 Posts: 6 Location: Pembrokeshire, United Kingdom Thanked: 0 times
Posted: Fri May 20, 2005 7:28 pm Post Subject: hot and cold water |
I recently replaced a section of pipe coming into the house and now I can't get water from the hot and cold taps at the same time. Any ideas? |
traineegasman
Joined: 29 Jan 2005 Posts: 382 Location: United Kingdom Thanked: 0 times
Posted: Fri May 20, 2005 7:36 pm Post Subject: |
Yes, put the piece of pipe back, & call a plumber... just a thought... |
kevplumb
Joined: 18 May 2004 Posts: 19144 Location: Tennessee, United States of America Thanked: 400 times
Posted: Fri May 20, 2005 7:41 pm Post Subject: |
the pipe was
where and what was it carrying
(ive put the crystal ball away )  __________________ a little thanks
goes a long way |
JPC
Joined: 10 Aug 2004 Posts: 1409 Location: Leicester, United Kingdom Thanked: 0 times
Posted: Fri May 20, 2005 8:07 pm Post Subject: |
he gets gas coming out of the hot tap ! __________________ Jamie |
agh81
JPC
Posted: Fri May 20, 2005 8:43 pm Post Subject: |
with the info u give its hard to help..if you have simply replaced then dunno ?...but have u...have u really...have u really sir....
come on u can tell us...u can...u now u can __________________ Jamie |
cozzmic
Joined: 20 Jan 2005 Posts: 428 Location: Nairnshire, United Kingdom Thanked: 5 times
Posted: Fri May 20, 2005 9:11 pm Post Subject: |
You might have got stones and sand in the pipe and it's gone and got itself stuck in the incoming supply valve in the house. Try turning off the valve in the house if it crunches there you go, or if you've got any filters on unvented hot water valves or combi boiler check them. Oh state the obvious have you turned the cold supply on proiperly outside, old valve 1/4 turn, new valves open like a tap. |
