DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Worcester 24i combi boiler problem!!!
Goto page 1, 2  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
Northwales01
from United Kingdom
PostPosted: Sat May 21, 2011 4:35 pm Reply with quote
Hopefully somebody can help with my boiler problem,
I have a 24i combi and it was working perfectly this morning, then this afternoon I went to turn the hot water on and just cold then went to turn heating on and nothing.
The fan still seems to be making a noise but where usually the ignition would spark after 20 seconds nothing happens and no flame.
Any help much appreciated.............
thanks in advance
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3427 times
PostPosted: Sat May 21, 2011 4:46 pm Reply with quote
Water pressure in the system?
Tony
Back to top
 Alert Moderators
Northwales01
from United Kingdom
PostPosted: Sat May 21, 2011 4:56 pm Reply with quote
don't think so as the pressure is staying at the correct level after I opened the valve and increased it, just not firing up!
Back to top
 Alert Moderators
martineire
from Ireland
Thanked: 13 times
PostPosted: Sat May 21, 2011 6:38 pm Reply with quote
Air pressure switch maybe, either way RGI neaded not a DIY job.
Back to top
 Alert Moderators
Northwales01
from United Kingdom
PostPosted: Sat May 21, 2011 7:56 pm Reply with quote
thanks for replies,
I gave the front of the boiler a bang and it sparked up, however it doesn't stay on as after 30 mins or so its back to square one! could this be something "sticking" inside the boiler?
Back to top
 Alert Moderators
Northwales01
from United Kingdom
PostPosted: Sat May 21, 2011 7:57 pm Reply with quote
also, pressure gauge seems to be staying near the red mark so no movement there
Back to top
 Alert Moderators
denso13
from United Kingdom
Thanked: 349 times
PostPosted: Sat May 21, 2011 8:29 pm Reply with quote
Is it the 24i RSF? Does putting pressure on the middle of the grey bottom panel bring it back to life?
Back to top
 Alert Moderators
Northwales01
from United Kingdom
PostPosted: Sat May 21, 2011 8:36 pm Reply with quote
Yes it is the 24i RSF, I have found that putting pressure on the main panel just by where the pilot light window is seems to work but no idea why!
Back to top
 Alert Moderators
denso13
from United Kingdom
Thanked: 349 times
PostPosted: Sat May 21, 2011 8:42 pm Reply with quote
Try pressing the middle of the bottom panel next time. If it works it sounds like a relay on the PCB, it is a common fault on these.
Back to top
 Alert Moderators
Northwales01
from United Kingdom
PostPosted: Sat May 21, 2011 8:49 pm Reply with quote
ahh right, could sound like the problem, do you know why banging it works?
Back to top
 Alert Moderators
denso13
from United Kingdom
Thanked: 349 times
PostPosted: Sat May 21, 2011 8:52 pm Reply with quote
The relay doesn't move/connect as it should. It seems to stick and a bang on the case might help it along.
Back to top
 Alert Moderators
Northwales01
from United Kingdom
PostPosted: Sat May 21, 2011 8:57 pm Reply with quote
sounds exactly what it could be, thanks
is the relay fixable or is a new PCB needed?
Back to top
 Alert Moderators
denso13
from United Kingdom
Thanked: 349 times
PostPosted: Sat May 21, 2011 9:18 pm Reply with quote
It's normally relay RL1 on the middle of the board (old one is usually blackened). RS Components (rs online) DPDT PCB power relay, 5A 24Vdc coil, part number 366-338. A lot cheaper than a new PCB.
Note - you should only carry out repairs that you are competent to do. Ensure you work safely at all times.
Back to top
 Alert Moderators
Northwales01
from United Kingdom
PostPosted: Sat May 21, 2011 9:35 pm Reply with quote
that's a great help thanks for that,
will probably have to pay someone to do the work but can order the part if it proves to be this
thanks again
Back to top
 Alert Moderators
martineire
from Ireland
Thanked: 13 times
PostPosted: Sun May 22, 2011 12:41 am Reply with quote
sounds good
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
Worcester Bosch 28CDi combi boiler hot water flow problem. 5 7500 Thu Mar 26, 2009 6:05 pm
Worcester 24i RSF-L Combi boiler problem 14 3860 Wed Oct 08, 2008 10:18 am
Worcester 24i Combi-Boiler problem - Please help 5 1360 Thu Jan 24, 2008 7:56 am
Worcester Combi boiler ignition problem 10 1440 Thu Dec 10, 2009 12:14 pm
Worcester 24i rsf combi boiler fiddly problem, please help 5 1320 Tue Nov 11, 2008 10:30 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
