m_ginty
Joined: 09 Feb 2005 Posts: 12 Location: United Kingdom
Posted: Mon Aug 08, 2005 6:48 pm |
Not sure if this is the best forum or whether my question should be in woodwork but here goes anyway...
I am hanging a new door and was drilling holes for the hinge screws and I've managed to snap a drill bit....
The bit isn't sticking out at all - in fact it's about .5 cm in.
How do I sort this mess out?!
thanks |
DAZB
Joined: 10 Sep 2002 Posts: 1082 Location: Leeds, United Kingdom Thanked: 76 times
Posted: Mon Aug 08, 2005 8:25 pm |
You could try a pair of long nose pliers on it and twist it out in reverse or maybe get a nail punch and , if there is room , knock it in deeper and out of the way. |
m_ginty
Posted: Mon Aug 08, 2005 9:19 pm |
I was thinking about knocking it further in -not sure how easy it will be - it's a hardwood external door.
Got some long nose pliers at work so will try them too.
thanks for the tips. |
big-all
Joined: 12 Jul 2004 Posts: 12079 Location: Surrey, United Kingdom Thanked: 651 times
Posted: Mon Aug 08, 2005 10:05 pm |
i assume your talking brass hinges and brass screws
dependant on wood [balsa is a hard wood  ]assuming youve using brass 8s
with brass hindges
hold in place with the other screws try inserting a steel screw[twin type ]and see how it goes it may just work in at an angle past the screw and sit in a reasonable position then replace with brass
if not youll probably have to rely on the other three screws!!!
it would help if the drill bit was pushed in a bit first as this would help the angle the screw goes in at |
nstreet
Joined: 22 Nov 2003 Posts: 1761 Location: United Kingdom Thanked: 1 time
m_ginty
Posted: Tue Aug 09, 2005 7:46 am |
Thanks for the advice, I'll have a go at it tonight |
big-all
Posted: Tue Aug 09, 2005 11:15 am |
if you do use a dowel as nstreat suggests
drill at a slight angle so even if the glue fails on dowel you will still get the screw in and out
of course insert screw at right angles as normal |
sidecar_jon
Joined: 05 Sep 2005 Posts: 342 Location: Cornwall, United Kingdom
Posted: Wed Sep 07, 2005 7:25 pm |
nar...cut the head off a screw and glue it over the hole....oops shouldnt have given that one away. |
