I have a problem with my gas central heating. It will switch on when it should gets up to whatever temperature its set to, but then when it tries to restart to maintain the heat nothing happens. To get it to work again I have to press the reset button on the boiler and then it fires back up. There is also a low droning noise coming from the airing cupboard where my tank is until the bolier is reset. Is this a thermostat problem or a valve not switching on again? My hot water is unaffected. Any help would be appreciated as I want to be able to explain things correctly to any engineer I call out.
