| Author |
Message |
maisiemouse
Joined: 28 Nov 2005 Posts: 1 Location: Armagh, United Kingdom
Posted: Mon Nov 28, 2005 10:35 am |
Hi, could someone help me, I recently bought a set of fairy lights from Thailand which had a funny two pin plug so i decided to cut it off and rewire it to a normal three pin but when i cut it there was no colours to tell me which was the live and neutral wires. Is there any way of finding out which is which? If i did wire it the wrong way what would be the result? Please could somebody help. thanks |
| Back to top |
If you do not want to see this advert, click here to login or if you are new click here to join free. |
ban-all-sheds
Joined: 27 Aug 2003 Posts: 41381 Location: London, United Kingdom Thanked: 1337 times
Posted: Mon Nov 28, 2005 11:03 am |
Not wishing to induge in any incompetent-johnny-foreigner stuff, but are you sure that these lights are safe?
Are they CE marked?
Are they marked as conforming to any quality/safety standard whatsoever?
Are they suitable for a 230V supply? |
| Back to top |
slippyr4
Joined: 12 Jul 2005 Posts: 709 Location: Bedfordshire, United Kingdom
Posted: Mon Nov 28, 2005 1:19 pm |
Thailand is 220V/50Hz. So, they'd probably technically work here, although might not be safe.
If they're incandescent lights, (not LED's), then it doesn't matter which you put in live, and which in neutral).
However, given that you can get 100 twinkly lights from woolies for less than a fiver, it seems a bit silly to take risks with unknown quality johnny-foreigner stuff. |
| Back to top |
ban-all-sheds
Posted: Mon Nov 28, 2005 1:24 pm |
| slippyr4 wrote: | | Thailand is 220V/50Hz. So, they'd probably technically work here, although might not be safe. | Unless made there for the Japanese or US market...
| Quote: | | However, given that you can get 100 twinkly lights from woolies for less than a fiver, it seems a bit silly to take risks with unknown quality johnny-foreigner stuff. |
Dodgy 230V lights wrapped around a tinder-dry resin-filled pine tree? What could go wrong?
OTOH - these could be the same lights that you buy in woolies...
Last edited by ban-all-sheds on Mon Nov 28, 2005 1:25 pm, edited 1 time in total |
| Back to top |
Adam_151
Joined: 17 Jun 2004 Posts: 5609 Location: United Kingdom Thanked: 118 times
| slippyr4 wrote: |
It wouldn't matter anyway, ... its AC, the worst that could happen is if its a really crap set that dosen't rectify to DC, they you'll end up changing which half cycle they light on |
| Back to top |
slippyr4
Posted: Mon Nov 28, 2005 1:31 pm |
| Adam_151 wrote: | | slippyr4 wrote: |
It wouldn't matter anyway, ... its AC, the worst that could happen is if its a really rubbish set that dosen't rectify to DC, they you'll end up changing which half cycle they light on |
I was thinking that LED lights would probably have some kind of a controller, which might care. |
| Back to top |
Adam_151
Posted: Mon Nov 28, 2005 2:02 pm |
| slippyr4 wrote: |
It couldn't possibly 'know' without an earth... |
| Back to top |
Steve
Joined: 15 Apr 2005 Posts: 15749 Location: Yorkshire, United Kingdom Thanked: 211 times
| Back to top |
slippyr4
Posted: Mon Nov 28, 2005 3:02 pm |
| crafty1289 wrote: | oooh now then . . . when i go to the shops and look at those white LED chains of xmas lights, they look like they are flickering very fast, is this because of the lack of a rectifier, and they are only lighting on half of the cycle?  |
the led lights flicker no more than a fluorescent tube. they've probably got an electronic controller for tacky effects. |
| Back to top |
plugwash
Joined: 28 Mar 2004 Posts: 7952 Location: United Kingdom Thanked: 125 times
Posted: Mon Nov 28, 2005 6:34 pm |
| slippyr4 wrote: |
the only reason you should ever need to care about live/neutral reversal with remotely modern equipment is correct operation of single pole isolation and protective devices. since theese lights presumablly have neither inside them it really shouldn't matter which way round you connect them.
the type of lamp is of absoloutely no significance whatsoever (it would be in a DC system but mains is AC). |
| Back to top |
Spark123
Joined: 02 Jun 2005 Posts: 13741 Location: Cumbria, United Kingdom Thanked: 338 times
Posted: Mon Nov 28, 2005 10:34 pm |
In 240v series type string where both the wires run together I like to wire L to the nearest lamp to the plug as this allows the use of an MK powertracer (or similar) to find the dud lamp.  |
| Back to top |
ban-all-sheds
Posted: Tue Nov 29, 2005 12:38 am |
Don't most lamps these days have internal links that close the circuit when they fail, so that the string doesn't go out?
Easy enough to spot the dud when they are off the tree - and when they are on there you don't know that one has gone, unless it's a really obvious one. |
| Back to top |
Steve
Posted: Tue Nov 29, 2005 7:47 pm |
| ban-all-sheds wrote: | | Don't most lamps these days have internal links that close the circuit when they fail, so that the string doesn't go out? |
yes they do, the only exception is the fuse bulb if the set has one.
incidentally, a few years ago, we bought a "pre-decorated" tree from b&q complete with a chain of 50 lights. After a few days of having it up, i noticed a few lights had gone out. odd, i thought, but left them be for a bit. Another few days passed, an i noticed the bulbs were very bright. i took them off the tree and more than half the bulbs had blown. I was quite shocked by this, since the bulbs that were burning, were taking twice their rated voltage, and producing more heat than they should, it could have easily caught fire on the tree. I was also worried about why the fuse bulb didn't blow . . . that's its job, isnt it, protecting against situations like this?
We took them back to b&q anyway, and they told us to pick another set of equivalent price. problem was, they dont sell this set of lights on their own, so how were we to know the set of 100 we picked was more expensive . . .  |
| Back to top |
plugwash
Posted: Tue Nov 29, 2005 9:32 pm |
| ban-all-sheds wrote: | Don't most lamps these days have internal links that close the circuit when they fail, so that the string doesn't go out?
| they do however such links are NOT 100% reliable! |
| Back to top |
