I have a Ideal W, RS 440 (ancient!!) boiler with a Myson dual-speed pump. Recently, I turned on my central heating to find that only the upstairs radiators were working, whilst the rads downstairs are totally COLD. As advised on the other messages on this forum, I\\\'ve tried bleeding all the rads, checked the water tank and even the pump (although I\\\'m not too sure whether the procedure is correct?!?) by touch to see whether the pipe temperature on both sides of the pump is the same. Which turns out to so. After all the checking I\\\'ve done best to my knowledge, the problem is still the same..COLD rads!!
Can someone please help me. Any help given will be much appreciated!!
Thanx.
Thanx.
