DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
extractor fan for tumble dryer
This topic originated from the How to page called Installing wiring for an extractor fan
Click here to return to the page called Installing wiring for an extractor fan.
  View previous topic :: View next topic
Author Message
cowboy plumber
from United Kingdom
Thanked: 0 times
PostPosted: Tue Apr 04, 2006 2:05 pm    Post Subject:
Reply with quote Thanks
We are going to move our tumble dryer to our new toilet room under the stairs, which is on the inside wall of a semi-detached. I want to install an extractor fan in the toilet and run a vent to the outside wall. I don't want to buy a new condensing tumble dryer.
My plan was to get a humidistat fan, and hook the vent from the tumble dryer on to the grill of the extractor fan. Can anyone advise whether this will work - or any problems I may encounter - also any better suggestions would be gratefully received.
Cheers.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Adam_151
from United Kingdom
Thanked: 10 times
PostPosted: Tue Apr 04, 2006 2:30 pm    Post Subject:
May I ask why you feel the need to put a fan on it, the normal way it just to hook the vent straight up through the wall, you may find with the fan that
a) there is not enough air flow through the tumbledryier for the fan to work properly, which could overheat the fan
b) the fan is designed for ambient temperature air, using it to move pre-heated air could cause it to overheat
c) the lint present might clog the fan and cause overheating
d) the tumbledryier may not work as well with more forced airflow being added than it was designed for
I also recommend you request that the mods move this to the appliances section
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Tumble Dryer 19 580 Mon Jul 14, 2008 2:41 pm
New condenser tumble dryer, newbie questions... 11 1260 Wed Dec 26, 2007 2:37 pm
Extending a flex on a tumble dryer 11 440 Tue Sep 23, 2008 4:58 am
Why dose this happen? tumble dryer/rcd question 7 420 Sun Nov 16, 2008 11:48 am
Tumble Dryer MCB 4 180 Sun Feb 15, 2009 8:51 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
