DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Wiring Standard Extractor Fan In Bathroom
This topic originated from the How to page called Installing wiring for an extractor fan
Click here to return to the page called Installing wiring for an extractor fan.
  View previous topic :: View next topic
Author Message
marc_123
from United Kingdom
Thanked: 0 times
PostPosted: Sat Apr 15, 2006 9:20 am    Post Subject:
Reply with quote Thanks
Hi folks,
I have a standard (not timer) extractor fan that should come on when light cord is pulled. The mains cable to the fan has blue, red and yellow wiring and the fan has 2 black wires going into a junction box. I\\\'ve connected the red and yellow from mains to the junction box but the fan works when the lights are off then goes off when the lights are on! This may sound dumb to the experienced but is there something obvious I\\\'m missing?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
dingbat
from United Kingdom
Thanked: 0 times
PostPosted: Sat Apr 15, 2006 10:46 am    Post Subject:
Haha, yes, you've used the wrong cores. You have wired your fan up to live and switched live, which means that when the lights are on there is no potential difference between these conductors, but when you turn the lights off there is mains potential. (Although how the circuit is actually completed is a bit of a mystery)
What on earth made you decide which conductors to use in the first place, or was it a purely random choice? Whatever your logic, or lack of logic, it indicates that you really shouldn't be playing with electricity - somebody might get hurt.
You need the neutral - probably the blue conductor - and the switched live - probably the yellow. But you should identify exactly which is which before you start mucking about.
If you didn't understand this, it makes me wonder what else you may have done wrong. (terminations, means of isolation, marking of conductors and basic testing immediately spring to mind.) Please call somebody who does this for a living and get it done safely.
Back to top
 Alert Moderators
marc_123
from United Kingdom
Thanked: 0 times
PostPosted: Sat Apr 15, 2006 6:26 pm    Post Subject:
Cheers for your help, I've isolated the permanent live and used switch live and neutral...all works now. Now all I need to do is sort out the hole in the ceiling(!)
M
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 14 times
PostPosted: Sat Apr 15, 2006 7:05 pm    Post Subject:
I won't ask why there's a hole in the ceiling.....
__________________
As George Michael once said, "..if you're gonna do it, do it right, right?"
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Bathroom extractor fans - standard or low voltage? 4 240 Sun Apr 26, 2009 9:04 pm
Fitting a standard bathroom extractor fan 5 7720 Mon Jan 08, 2007 5:56 pm
Standard Ceiling Rose in Bathroom 8 400 Thu Aug 28, 2008 7:10 pm
change bathroom pull switch to standard switch. 5 440 Mon Jun 23, 2008 10:16 am
standard wiring for a british gas wall plate for a programme 3 160 Sat Nov 29, 2008 4:36 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
