I currently have just fitted a gravity fed shower with a 6" shower rose although as the pressure is not enough to cause more than i trickle, i have contemplated fitting a small pump. However i have been told that unless i put second water tank in my loft i run the risk of running my hot water system dry causing all sorts of problems.
Does anyone know if there is a small pump on the market just enough to power my shower that will not cause the above problem?
Thankyou.
Thankyou.
