DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
FCU on a 45amp radial cooker circuit?
This topic originated from the How to page called Fitting a Fused Connection Unit
Click here to return to the page called Fitting a Fused Connection Unit.
  View previous topic :: View next topic
Author Message
BEdwards
from United Kingdom
Thanked: 0 times
PostPosted: Sat May 27, 2006 7:38 pm    Post Subject:
Reply with quote Thanks
Can a 3amp fused connection unit be added after the terminal outlet of my 45amp radial cooker circuit? I have just unpacked our new gas hob to find that the ignition is supplied from the mains. Am kicking myself because we had the kitchen rewired last month and I didn't think to specify that a socket should be sited next to the terminal outlet for the cooker so I could plug in the hob (Our old gas cooker had an AA batery to supply the ignition). It would be helpful if a three amp fused connection unit could be added to the end of the radial circuit. Any comments would be much appreciated.
Ben
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Sat May 27, 2006 7:42 pm    Post Subject:
in theory yes, but you wont be able to get the cable into the fcu as it will be too big, and before you ask, no you can not use a smaller cable to feed the fcu,
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
BEdwards
from United Kingdom
Thanked: 0 times
PostPosted: Sat May 27, 2006 7:55 pm    Post Subject:
I guess you can't get 45amp rated FCUs then. Damn an blast!! Should have unpacked the hob earlier. Guess I'll just have to run an extension lead under the units from the closest socket. Either that or buy a box of matches. Thanks for your reply.
Ben
Back to top
 Alert Moderators
plugwash
from United Kingdom
Thanked: 15 times
PostPosted: Sat May 27, 2006 9:00 pm    Post Subject:
depending on how the cables routed you may be able to place a small consumer unit in an adjacent cupboard and use that to feed both oven and hob.
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
New Induction Hob and Double Oven is 45amp circuit enough? 2 840 Thu Feb 22, 2007 3:47 pm
45amp cooker cable to 13 amp switches 15 880 Wed Feb 02, 2005 4:54 pm
45amp cooker socket 3 4660 Fri Jun 15, 2007 11:13 am
45amp Ceiling Pull Cord Switch keeps blowing 5 260 Sat Jan 24, 2009 8:00 am
Swap a 32AMP Switch with a 45AMP switch! 9 340 Fri Sep 04, 2009 7:42 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
